Этот пример является устаревшим, посмотрите множество других обновлённых примеров в данной категории.This example shows how to use designer events. First, import scripts:
import { StimulsoftViewerModule } from 'stimulsoft-viewer-angular';
import { StimulsoftDesignerModule } from  'stimulsoft-designer-angular';
	imports: [
		StimulsoftViewerModule,
		StimulsoftDesignerModule,
Next, define URL template to server controller, initial action and parameters of designer and viewer:
<stimulsoft-viewer-angular
  *ngIf="showViewer"
  [requestUrl]="'http://localhost:60801/Viewer/{action}'"
  [action]="'InitViewer'"
  [height]="'600px'"
  (design)="showViewer = false"
></stimulsoft-viewer-angular>
<stimulsoft-designer-angular
  *ngIf="!showViewer"
  [requestUrl]="'http://localhost:60801/api/designer'"
  [height]="'600px'"
  [width]="'100%'"
  Loading designer...
</stimulsoft-designer-angular>
Then, create DesignerController. Next, set the required options on the server side:
[HttpPost]
public IActionResult Get()
	// Setting the required options on the server side
	var requestParams = StiAngularDesigner.GetRequestParams(this);
	if (requestParams.Action == StiAction.Undefined)
		var options = new StiAngularDesignerOptions();
		return StiAngularDesigner.DesignerDataResult(requestParams, options);
	return StiAngularDesigner.ProcessRequestResult(this);
[HttpPost]
public IActionResult Post()
	if (requestParams.ComponentType == StiComponentType.Designer)
		switch (requestParams.Action)
			case StiAction.GetReport:
				return GetReport();
			case StiAction.SaveReport:
				return SaveReport();
After that, load a report:
public IActionResult GetReport()
	var report = StiReport.CreateNewReport();
	var path = StiAngularHelper.MapPath(this, $"Reports/MasterDetail.mrt");
	return StiAngularViewer.GetReportResult(this, report);
Next, create a method to save report:
public IActionResult SaveReport()
	var report = StiAngularDesigner.GetReportObject(this);
	var path = StiAngularHelper.MapPath(this, "Reports/MasterDetail.mrt");
	report.Save(path);
	return StiAngularDesigner.SaveReportResult(this);
Finally, create ViewerController and enable design button in the viewer options in initialization:
[HttpPost]
public IActionResult InitViewer()
	var requestParams = StiAngularViewer.GetRequestParams(this);
	var options = new StiAngularViewerOptions();
	options.Actions.GetReport = "GetReport";
	options.Actions.ViewerEvent = "ViewerEvent";
	options.Appearance.ScrollbarsMode = true;
	options.Toolbar.ShowDesignButton = true;
	return StiAngularViewer.ViewerDataResult(requestParams, options);
Using Designer Events
