Этот пример является устаревшим, посмотрите множество других обновлённых примеров в данной категории.This example shows how to use viewer events. First, import scripts:
import { StimulsoftViewerModule } from 'stimulsoft-viewer-angular';
	imports: [
		StimulsoftViewerModule,
Next, define URL template to server controller, initial action and viewer height:
<stimulsoft-viewer-angular
	[requestUrl]="'http://localhost:60801/Viewer/{action}'"
	[action]="'InitViewer'"
	[height]="'600px'"
	(loaded)="loaded()"
	(export)="export($event)"
></stimulsoft-viewer-angular>
Then, create ViewerController. Next, initialize the viewer:
[HttpPost]
public IActionResult InitViewer()
	var requestParams = StiAngularViewer.GetRequestParams(this);
	var options = new StiAngularViewerOptions();
	options.Actions.GetReport = "GetReport";
	options.Actions.ViewerEvent = "ViewerEvent";
	options.Appearance.ScrollbarsMode = true;
	return StiAngularViewer.ViewerDataResult(requestParams, options);
After that, get report:
[HttpPost]
public IActionResult GetReport()
	var report = StiReport.CreateNewReport();
	var path = StiAngularHelper.MapPath(this, $"Reports/MasterDetail.mrt");
	return StiAngularViewer.GetReportResult(this, report);
Finally, process other viewer requests:
[HttpPost]
public IActionResult ViewerEvent()
	return StiAngularViewer.ViewerEventResult(this);
Using Viewer Events
