Этот пример является устаревшим, посмотрите множество других обновлённых примеров в данной категории.This example shows how to use viewer parameters. First, import scripts:
import { StimulsoftViewerModule } from 'stimulsoft-viewer-angular';
	imports: [
		StimulsoftViewerModule,
Define properties:
properties = { reportName: this.reports[0] };
Then, create selector with items:
<select (change)="updateProps($event.target.value)">
  <option *ngFor="let item of reports" [value]="item">{{ item }}</option>
</select>
Next, define URL template to server controller, initial action, properties and viewer height:
<stimulsoft-viewer-angular
	[requestUrl]="'http://localhost:60801/Viewer/{action}'"
	[action]="'InitViewer'"
	[height]="'600px'"
	[properties]="properties"
></stimulsoft-viewer-angular>
Then, create ViewerController. Next, initialize the viewer:
[HttpPost]
public IActionResult InitViewer()
	var requestParams = StiAngularViewer.GetRequestParams(this);
	var options = new StiAngularViewerOptions();
	options.Actions.GetReport = "GetReport";
	options.Actions.ViewerEvent = "ViewerEvent";
	options.Appearance.ScrollbarsMode = true;
	return StiAngularViewer.ViewerDataResult(requestParams, options);
After that, load a report:
[HttpPost]
public IActionResult GetReport()
	var reportName = "MasterDetail.mrt";
	var httpContext = new Stimulsoft.System.Web.HttpContext(this.HttpContext);
	var properties = httpContext.Request.Params["properties"]?.ToString();
	if (properties != null)
		var data = Convert.FromBase64String(properties);
		var json = Encoding.UTF8.GetString(data);
		JContainer container = JsonConvert.DeserializeObject<JContainer>(json);
		foreach (JToken token in container.Children())
			if (((JProperty)token).Name == "reportName")
				reportName = ((JProperty)token).Value.Value<string>();
	var report = StiReport.CreateNewReport();
	var path = StiAngularHelper.MapPath(this, $"Reports/{reportName}");
	return StiAngularViewer.GetReportResult(this, report);
Finally, process other viewer requests:
[HttpPost]
public IActionResult ViewerEvent()
	return StiAngularViewer.ViewerEventResult(this);
Using Viewer Parameters
