Этот пример является устаревшим, посмотрите множество других обновлённых примеров в данной категории.This sample project demonstrates how to connect to data from the code. First of all, use show() method to show the report:
private void ShowReport(DataSet dataSet)
	report.Load(@"Reports\TwoSimpleLists.mrt");
	report.Dictionary.Databases.Clear();
	report.RegData("Demo", dataSet);
	report.Show();
Then, connect to data and call ShowReport method:
private void buttonXml_Click(object sender, EventArgs e)
	var dataSet = new DataSet();
	dataSet.ReadXmlSchema(@"Data\Demo.xsd");
	dataSet.ReadXml(@"Data\Demo.xml");
	ShowReport(dataSet);
private void buttonJson_Click(object sender, EventArgs e)
	var dataSet = StiJsonToDataSetConverterV2.GetDataSetFromFile(@"Data\Demo.json");
Connecting to Data from Code
