Этот пример является устаревшим, посмотрите множество других обновлённых примеров в данной категории.This example shows how to add connect to data from the code.
First, you need to add the StiNetCoreViewer component to the view page:
@using Stimulsoft.Report.Web;
@using Stimulsoft.Report.Mvc;
@Html.StiNetCoreViewer(new StiNetCoreViewerOptions()
    Actions =
        GetReport = "GetReport",
        ViewerEvent = "ViewerEvent"
In the options above we define several actions, and we need to add it in the controller.
The GetReport() action loads the report template and data, after thet it returns answer to the client part of the viewer using the GetReportResult() static method:
public IActionResult GetReport()
	// Loading the report template
	var reportPath = StiNetCoreHelper.MapPath(this, "Reports/TwoSimpleLists.mrt");
	report.Load(reportPath);
	// Deleting connections in the report template
	report.Dictionary.Databases.Clear();
	// Loading data from the XML file
	var dataPath = StiNetCoreHelper.MapPath(this, "Reports/Data/Demo.xml");
	var data = new DataSet();
	data.ReadXml(dataPath);
	// Registering data in the report
	report.RegData(data);
	// Syncing the data structure, if required
	//report.Dictionary.Synchronize();
	return StiNetCoreViewer.GetReportResult(this, report);
Now, let's try with Designer:
@Html.StiNetCoreDesigner(new StiNetCoreDesignerOptions()
	Actions =
		PreviewReport = "PreviewReport",
		DesignerEvent = "DesignerEvent"
You can use PreviewReport() method to load data:
 public IActionResult PreviewReport()
	// Getting a preview report
	var report = StiNetCoreDesigner.GetActionReportObject(this);
	return StiNetCoreDesigner.PreviewReportResult(this, report);
Connecting to Data from Code
